Введение
This guide will give step by step instructions showing how to repair the microphone on the Samsung Gear S.
Выберете то, что вам нужно
Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
Locate the microphone on the lower right corner of the plastic motherboard assembly .
3 участников успешно повторили данное руководство.
3 Комментариев
any chance of posting were to buy a new mic please..
