Введение
Have your applications or watch become unresponsive? Replacing the motherboard may fix these issues.
Выберете то, что вам нужно
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
Using the flat end of a spudger, pry up the motherboard.
The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
7 участников успешно повторили данное руководство.
6 Комментариев
Where do you get the mother board.
I'm looking for a new motherboard as well.
Karen -
Do you have a good source for motherboards? Hope it helps that I +30’d you!
