Samsung Gear S3 Frontier Bezel Ring Replacement
Выберете то, что вам нужно
  1. Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: шаг 1, изображение 1 из 3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: шаг 1, изображение 2 из 3 Samsung Gear S3 Frontier Bezel Ring Replacement, Bezel Ring: шаг 1, изображение 3 из 3
    • Contains small springs and ball bearings. We suggest working over a plate or tray.
    • Hold the watch firmly in one hand, face up.
    • Place the iFixit Opening Tool under the bezel ring and use prying motion to remove.
    • The plastic retainer is manufactured with an open gap, you did not break it.
    • For reassembly, set the plastic retainer in the ring, then press the ring down until it snaps in place.
Заключение
26 участников успешно повторили данное руководство.
Mark Iknoian
Участник с: 10/08/18
1 027 Репутация
1 руководство автора
Команда
Cal Poly, Team S15-G2, White Fall 2018 Участник Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 членов
Автор 34 руководств
42 Комментариев
I got the bezel popped off to clean it. Now it wont pop back on! Help!
shileski - Ответить
line up the bezel with the screen and push it in
Arthur -
I’ve tried lining it up with the screen and pushing it in about 50 times now and everytime I do it clicks, but after rotating it a few times the bezel locks and I can’t rotate it anymore. YES all the ball bearings are in the right place, YES the springs are in the right place. There’s this little plastic piece that I can’t tell if it goes inside the bezel piece or if it goes on top of the watch next to the ball bearings. I’m able to get the bezel back on when I put the little plastic piece on the bezel, it clicks right in, but it locks up. When I leave the little plastic piece on the watch I can’t get it to click in at all. I think I just royally f’ed up my watch!
Hardy T - Ответить
did u manage to fix it?
Dave Green - Ответить
Interested to know if anyone had much success with this process.
Seth Armour - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 94
За последние 30 дней: 377
За всё время: 85,924
