Samsung Gear VR Motherboard Replacement
Выберете то, что вам нужно
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: шаг 1, изображение 1 из 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: шаг 1, изображение 2 из 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: шаг 1, изображение 3 из 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: шаг 2, изображение 1 из 2 Samsung Gear VR  Motherboard Replacement: шаг 2, изображение 2 из 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: шаг 4, изображение 1 из 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
Заключение
David Forlano
Участник с: 09/25/17
119 Репутация
1 руководство автора
Команда
USF Tampa, Team S4-G6, Eyestone Fall 2017 Участник USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 членов
Автор 7 руководств
Один комментарий
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 1,519
