Samsung Gear VR Inner Mask Replacement
Выберете то, что вам нужно
  1. Samsung Gear VR Inner Mask Replacement, Front Phone Mount: шаг 1, изображение 1 из 3 Samsung Gear VR Inner Mask Replacement, Front Phone Mount: шаг 1, изображение 2 из 3 Samsung Gear VR Inner Mask Replacement, Front Phone Mount: шаг 1, изображение 3 из 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Inner Mask Replacement: шаг 2, изображение 1 из 2 Samsung Gear VR Inner Mask Replacement: шаг 2, изображение 2 из 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR Inner Mask Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR Inner Mask Replacement: шаг 4, изображение 1 из 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
  5. Samsung Gear VR Inner Mask Replacement, Inner Mask: шаг 5, изображение 1 из 3 Samsung Gear VR Inner Mask Replacement, Inner Mask: шаг 5, изображение 2 из 3 Samsung Gear VR Inner Mask Replacement, Inner Mask: шаг 5, изображение 3 из 3
    • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
    • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
Заключение
Abraham Rodriguez
Участник с: 09/25/17
236 Репутация
Автор 2 руководств
Команда
USF Tampa, Team S4-G6, Eyestone Fall 2017 Участник USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 539
