Введение
Use this guide to replace your cracked or otherwise damaged front panel, including the front glass, digitizer, and front panel buttons.
Выберете то, что вам нужно
Remove the battery by pulling up from the bottom right corner.
Remove the SIM card and the Micro SD card.
SIM card
Micro SD card
Use a plastic opening tool to pry off the casing.
Lock button
Camera button
Volume button
Disconnect the LCD cable with a plastic opening tool.
Remove the two 2.8 mm Phillips screws that hold the motherboard in place.
Remove the six 1.5 mm Phillips screws.
Very gently peel the LCD cord off the slider assembly.
I found that my plastic opening tool wasn't strong enough (it broke) to pry open this casing.
I used a 1.3 mm Flathead screwdriver as an opening tool.
After you have gotten under the edge of the back plate, slide your tool along the length of the plate.
Remove the cover.
I found these clips to be the hardest to remove.
After removing the yellow clips, these should follow easily.
It's time to take the LCD out.
Begin by removing the blue piece of tape.
2 участников успешно повторили данное руководство.
