Samsung Gravity TXT Motherboard Replacement
Выберете то, что вам нужно
  1. Samsung Gravity TXT Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 Samsung Gravity TXT Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT Motherboard Replacement: шаг 2, изображение 1 из 1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT Motherboard Replacement: шаг 3, изображение 1 из 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT Motherboard Replacement, SIM Card: шаг 4, изображение 1 из 3 Samsung Gravity TXT Motherboard Replacement, SIM Card: шаг 4, изображение 2 из 3 Samsung Gravity TXT Motherboard Replacement, SIM Card: шаг 4, изображение 3 из 3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
  5. Samsung Gravity TXT Motherboard Replacement, microSD Card: шаг 5, изображение 1 из 3 Samsung Gravity TXT Motherboard Replacement, microSD Card: шаг 5, изображение 2 из 3 Samsung Gravity TXT Motherboard Replacement, microSD Card: шаг 5, изображение 3 из 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
  6. Samsung Gravity TXT Motherboard Replacement, Plastic Back Frame: шаг 6, изображение 1 из 1
    • Remove the six 3 mm #00 Phillips screws in the plastic back frame.
  7. Samsung Gravity TXT Motherboard Replacement: шаг 7, изображение 1 из 3 Samsung Gravity TXT Motherboard Replacement: шаг 7, изображение 2 из 3 Samsung Gravity TXT Motherboard Replacement: шаг 7, изображение 3 из 3
    • Slide the keyboard out.
    • Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
    • Starting at the bottom of the keyboard is recommended.
    • Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
    • You will have to slide the keyboard back in to separate the back frame from the top have of the keyboard slider.
    • Lift the plastic back frame away.
  8. Samsung Gravity TXT Motherboard Replacement, Motherboard: шаг 8, изображение 1 из 1
    • Remove the two 3 mm Phillips #00 screws securing the motherboard to the front panel.
    • Do not try to pull the motherboad out just yet. The display data cable needs to be disconnected from the motherboad first.
  9. Samsung Gravity TXT Motherboard Replacement: шаг 9, изображение 1 из 3 Samsung Gravity TXT Motherboard Replacement: шаг 9, изображение 2 из 3 Samsung Gravity TXT Motherboard Replacement: шаг 9, изображение 3 из 3
    • Use your finger nail to disconnect the display data cable from the motherboard.
  10. Samsung Gravity TXT Motherboard Replacement: шаг 10, изображение 1 из 2 Samsung Gravity TXT Motherboard Replacement: шаг 10, изображение 2 из 2
    • Carefully lift the main motherboard assembly away from the front panel.
Заключение
Mounir Karmada
Участник с: 07/07/15
465 Репутация
Автор 4 руководств
Команда
IUPUI, Team 1-1, Renguette SU 2015 Участник IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 382
