Введение
Cracked or faulty LCD screens can make the HMX-F90 difficult to use. This guide can be used to replace the flip-out LCD screen.
Выберете то, что вам нужно
Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
Rotate the camcorder so that it is facing you.
Locate and remove the two 4.5mm Phillips #00 screws.
Open the LCD screen and rotate it around 90 degrees.
Locate the small prying notch and use a prying tool to slowly remove the LCD cover.
With tweezers gently unclip the silver tab holding the ribbon wire.
Gradually feed the ribbon wire through the hole to remove the screen.
