Введение
How to remove & replace the phone's antenna.
Инструменты
Запчасти
Детали не указаны.
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Grip the battery on its sides, opposite the direction of the white arrow.
Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
Snap off the back cover by gently prying around the top and bottom edges with a flat head screwdriver.
The side buttons will become loose and are prone to falling out, so put these in a safe place.
To free the circuit board, remove the black wire that is holding it down.
The circuit board will still be held on by a blue and black ribbon that is removed by gently pulling it upwards.
Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
The antenna assembly will snap off.
Еще один человек закончил это руководство.
