Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
How to remove & replace the phone's back cover.
Выберете то, что вам нужно
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
Pry the battery free. It will pivot in the direction of the white arrow.
Remove the six 3.5 mm Phillips #000 screws, using a Phillips #000 screwdriver.
Remove the back cover by gently prying around the top and bottom edges with a nylon spudger.
The side buttons will become loose and are prone to falling out, so put these in a safe place.
