Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
Pry the battery free. It will pivot in the direction of the white arrow.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
Remove the back cover by gently prying around the top and bottom edges with the spudger.
The side buttons will become loose and will fall out, so put these in a safe place.
To free the circuit board, remove the black wire that is holding it down.
The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
The antenna assembly will snap off.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
Remove 6 screws holding the silver plate on.
2.7mm in length
The keys will peel right out of the screen side of the phone.
The silver piece you are left with is the physical keyboard assembly.
