Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows all the steps leading up to, and including, removing the speaker so that a new one can be installed.
Выберете то, что вам нужно
Apply pressure to the back cover and slide it forward towards the camera.
Lift the back cover off the phone.
Use the plastic opening tool to unhinge the locks around the edges of the phone.
Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
Remove the two 3.50mm screws connecting the motherboard to the case.
Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
Using tweezers to grasp the pins of the speaker, gently lift the speaker up out of its setting in the front case.
