Введение
Use this guide to install a rear case.
Запчасти
Никакие детали не требуются.
  1. Slide the battery cover downwards with pressure focused on the center of the cover.
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Grasp the bottom left and right corners of the battery and lift it from its housing.
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    • Lift the rear case off of the phone.
Заключение
Paul Piller
Участник с: 12.04.2011
56 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 24-57, Amido Spring 2011 Member of Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,060
