Выберете то, что вам нужно
Use a case opening tool to gently split the upper and lower case
Work around the entire case until the 2 halves come apart completely
Release the circuit board by gently pushing the plastic tab away from the board
Lift circuit board off top cover to expose the rubber button membrane
Lift off the rubber button membrane
During reassembly make sure that you correctly place the battery cover retainer on the read case
When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover
9 участников успешно повторили данное руководство.
