Samsung LN40C530F TV Board(s) Replacement
Выберете то, что вам нужно
    • Be sure to unplug the TV from the main wall outlet.
    • Carefully lay the TV screen down on a clean flat table with the back side facing you.
    • Using a #3 Phillips head screwdriver, remove the screws holding the back cover on.
    • Thoroughly clean the cover and boards using a damp towel (I like to use 91% isopropyl alcohol) and if heavily soiled use a vacuum with a brush.
  1. Samsung LN40C530F TV  Board(s) Replacement, Remove Power Supply Board: шаг 2, изображение 1 из 1
    • Using the #3 Phillips head screwdriver, remove the screws holding the power supply board on.
    • Unplug the connectors connected to the board setting aside and carefully noting placement for later connection to the new board.
    • Insert the new power supply board into the location where the old board was located.
    • Follow the previous steps to connect the cables and screw in the screws.
    • Using the #3 Phillips head screwdriver, remove the screws holding the main board on.
    • Insert the new main board into the location where the old board was located.
    • Follow the first step in reverse to install the back cover.
    • Plug the power cord into a wall outlet and power on the TV to verify performance.
Заключение
Еще один человек закончил это руководство.
James Finch
Участник с: 10/14/17
2 268 Репутация
Автор 13 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 30
За всё время: 3,006
