Выберете то, что вам нужно
Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
Remove the six 2.5 mm Philips #2 screws on the front of the device surrounding the speakers using the Screwdriver PH2 Philips Head.
Remove the eight 1.6 mm Philips #1 screws from the sides, front, and back of the device using the Screwdriver J000 Philips Head.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Using the anti-static wrist strap and the metal spudger, remove the wires from the speakers.
To put the replacement speakers onto the device, use a soldering tool to solder the wires onto the new speakers.
6 участников успешно повторили данное руководство.
2 Комментариев
Só tem esse video que mostra passo a passo como desmontar o Samsung Level Box Mini.
Obrigado por compartilhar amigo, espero que esse video ajude outras pessoas.
