Выберете то, что вам нужно
Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
Remove the six 2.5 mm Philips #2 screws on the front of the device surrounding the speakers using the Screwdriver PH2 Philips Head.
Remove the eight 1.6 mm Philips #1 screws from the sides, front, and back of the device using the Screwdriver J000 Philips Head.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Using the anti-static wrist strap and the metal spudger, remove the wires from the speakers.
To put the replacement speakers onto the device, use a soldering tool to solder the wires onto the new speakers.
6 участников успешно повторили данное руководство.
2 Комментариев
Só tem esse video que mostra passo a passo como desmontar o Samsung Level Box Mini.
Obrigado por compartilhar amigo, espero que esse video ajude outras pessoas.
