Введение
This guide will go over where to locate and replace the rear cooling fan. You will need to reference the Removing Samsung ML2510 Back Panel repair guide to complete this one.
Запчасти
No parts specified.
  1. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
    • Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
  2. Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2  screws on the back of the printer.
    • Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2 screws on the back of the printer.
  3. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  4. Gently lift the top panel while simultaneously pulling off the back panel. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  5. Once the fan is detached, unplug the fan from the circuit board. Slide the fan's wiring through the anchored slit.
    • Once the fan is detached, unplug the fan from the circuit board.
    • Slide the fan's wiring through the anchored slit.
  6. With the new fan, thread the wiring through the old fan's slit.
    • With the new fan, thread the wiring through the old fan's slit.
    • Reconnect the fan by plugging it back into the circuit board.
    • Reattach the back panel following these instructions in reverse order.
Финишная черта
bbaustin
Участник с: 12.10.2011
199 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 17-18, Regan Fall 2011 Member of Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 членов
Автор 6 руководств
Один комментарий
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 2,865
