Введение
This guide will require you to disassemble the back and side panel of the printer. You will need to refer to the Removing Samsung ML2510 Back Panel guide in order to complete the task.
Выберете то, что вам нужно
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
Locate the holes on the panel that are attached to the main body.
Remove the front panel by gently moving the holes from the pegs one by one.
Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
Using a plastic opening tool, gently lift one side of the top panel from its peg.
Repeat process for the other side.
Lift the top panel from the front to remove it entirely.
Lift the right side-panel up from the raised stops.
Gently rotate the panel as indicated in the picture to remove the panel entirely.
Unplug the fan's wires from the side circuit board.
Replace the fan and reassemble the printer using reverse procedures.
2 участников успешно повторили данное руководство.
