Выберете то, что вам нужно
Slide the lock towards the middle of the camera, in the same direction of the arrow.
Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
Remove the 2.381 mm screw that is holding the copper to the control board with a Phillips #00 screw driver.
Use the plastic opening tool to pry the control board up, thus allowing the flash bulb assembly to be removed.
Beginning with the battery on the side, gently pull upwards to remove the entire flash bulb assembly.
