Введение
This guide details how to install a new camera button on your Samsung Moment SPH M900. The camera button is located on the lower right side, distinguished by a black line. We provide directions for both disassembly and reassembly.
Выберете то, что вам нужно
Power off the phone using the "Power Button", the circular middle button in the center of the phone.
Locate the camera button on bottom right side of your phone
Remove the back panel of the phone by sliding the spudger along the edge of the phone. The rear plastic panel will snap off from the remainder of the phone.
If you have not already removed the memory card, remove it by gently sliding it out of its holder.
Using the small Phillips #000 screw driver, remove the six screws from the back of the phone.
Using the spudger tool, separate the back housing from the phone.
If the camera button did not fall, carefully remove it using a pair of tweezers. At this point, you can replace the button with a new one.
Be sure to gently slide the memory card back in its holder.
3 участников успешно повторили данное руководство.
