Введение
This guide will show you how to replace your microphone.
Выберете то, что вам нужно
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Place your finger on either bottom corner of the battery slot and lift to remove the battery.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
Working along the seam, pry the back casing from the phone.
Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
Carefully lift the capacitor away from the phone.
Carefully tilt the motherboard up from the back of the phone.
Use tweezers to unclip the black connector.
Hold the phone by the black plastic at the ends and gently bend them down so that the middle of the phone is the highest point. Apply pressure slowly until the grey portion pops off.
