Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace the motherboard of the Samsung Mythic SGH-a897.
Выберете то, что вам нужно
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Place your finger on either bottom corner of the battery slot and lift to remove the battery.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
Working along the seam, pry the back casing from the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
Firmly grip the black lever with tweezers
Use the tweezers to flip the black lever up so that it is perpendicular to the motherboard.
Use the tweezers to unclip the orange flexible circuit board from the side of the phone.
Slide one side of the tweezers underneath the red and blue wires of the capacitor.
Carefully apply pressure away from the phone to lift.
Carefully tilt the motherboard up from the back of the phone.
Use tweezers to unclip the black connector.
