Введение
After removing the back cover and the battery from the Samsung Mythic SGH-a897, the rear case must be removed to reach the motherboard. The tools needed are the iFixit Opening Tool to remove the rear casing and a screwdriver to remove six 5mm Phillips #0 screws.
Выберете то, что вам нужно
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Place your finger on either bottom corner of the battery slot and lift to remove the battery.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
Working along the seam, pry the back casing from the phone.
