Введение
This guide will show how to remove the back cover from the laptop in order to access the parts inside the computer.
This guide will be a pre-requisite guide for replacing the hard drive, and cooling fan.
Выберете то, что вам нужно
Slide the battery switch to the unlock symbol, and the battery will pop up.
Remove the battery.
Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
Insert the plastic opening tool in the break between the back panel, and the keyboard.
Drag the opening tool around the edge to separate it.
Pull the back panel off of the laptop.
