Введение
Laptop batteries are the part most likely to fail, and usually the first to fail. This guide will show you how to replace a dead or malfunctioning battery.
With both thumbs, slide the switches outward, away from the center of the laptop.
Using your index fingers, push the battery outward, toward your body. The angle is somewhat awkward, but don't be afraid to use a little force. The battery should slide out in one motion.
Еще один человек закончил это руководство.
