Введение
In this guide, we will demonstrate how to replace the hard drive of your Samsung NP-N102S-B05PH laptop.
Replacing the hard drive is a quick way to solve any issues resulting from common hard drive issues including; a slow startup, random crashes, corrupted files, and problems with opening files and media. A faulty drive can result from many things, including running at total or near-full capacity.
If the hard drive has been tested and is causing issues, it's a good idea to replace it and possibly upgrade storage capacity.
Before beginning this repair, power off your laptop and unplug your device from the power adapter.
Выберете то, что вам нужно
Power down your laptop, and position the laptop with the bottom cover facing upwards.
Use a Phillips #0 screwdriver to remove the four 4.5 mm bracket screws holding the hard drive onto the motherboard.
Lift the hard drive up and gently pull off the SATA cable that is currently connected to the board.
Еще один человек закончил это руководство.
