Введение
This guide will provide instructions on how to fully replace the battery on a Samsung N145 laptop. You will be given steps on how to detach the current fan on your device and attach a new one. You will want to perform this replacement if your current laptop fan is broken/damaged, or if the device begins to overheat.
Выберете то, что вам нужно
Remove the back of the device from the main frame by unscrewing the 14 4.5 mm screws using a Phillips #0 screwdriver.
Once all screws are out, pry open the back cover piece of the device using a plastic opening tool.
Remove the four 6.5 mm screws that surround the fan using the PH1 Phillips screwdriver head.
