Введение
This guide will provide instructions on how to entirely replace the screen of a Samsung N145 laptop. You will be given steps on how to detach a the screen on your device and attach a new one. You will want to perform this replacement when the screen no longer works or randomly blacks out when being used.
Выберете то, что вам нужно
Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
Use a blue prying tool to pry the screen frame off.
Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
