Введение
Follow this guide to replace/upgrade your hard drive.
A hard drive replacement is helpful if your device is won't boot or crashes continually. Make sure your replacement hard drive is compatible with the Samsung NP-N210-JA02US.
Выберете то, что вам нужно
Remove the following 14 screws:
Thirteen 5 mm Phillips #1 screws
One 3.5 mm Philips #001 screw
Carefully insert the plastic opening tool into the seam between the lower casing and the chrome bezel.
Slide the opening tool across all sides of the lower case. Then, lift it up to remove the case and reveal the internal components.
9 участников успешно повторили данное руководство.
