Введение
Is your computer not loading filed properly or are you out of storage? Consider using this guide to replace the hard drive in your laptop.
Выберете то, что вам нужно
Flip the device to the bottoms-up position and locate the panel that says HDD.
Remove the two 3.7mm securing screws with a Phillips #0 screwdriver.
After removing the screws, remove the panel covering the HDD.
Remove the screws on the bracket and then remove the bracket by pulling up.
Once the bracket has been removed, slide the hard drive towards the gap in the cavity and then remove it from the device.
2 участников успешно повторили данное руководство.
