Введение
Given to us to find out whats happened to the keyboard (Sticky keys), thought it might be helpful to post a guide
Выберете то, что вам нужно
Quite a simple stage. There are a total of 19 screws to be removed from the bottom of the casing.
Three for HDD
One for Ram/HDD Cover
One for ODD
one hidden under a rubber foot at the front of the laptop.
Three under the Battery
Make sure you remove the fake SD Card at the front, because this can stall you.
Once the cover is off, there are three screws holding the main PCB down.
Screws for the HDD
Battery. DC 11.1V 57W
removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side.
Here's the underside of the main PCB, all cables detached.
With the PCB removed this is all you have left.
3 участников успешно повторили данное руководство.
