Введение
This guide will help you replace your faulty battery. You may want to use this guide if your computer does not power on.
Turn your laptop upside down so that the battery component is facing you.
Place your thumbs on the lock tabs.
Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
Pull the battery out of the laptop towards yourself to safely remove the battery.
3 участников успешно повторили данное руководство.
