Samsung NP305E5A-A03US Hard Drive Replacement
Выберете то, что вам нужно
  1. Samsung NP305E5A-A03US Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Hard Drive Replacement: шаг 3, изображение 1 из 2 Samsung NP305E5A-A03US Hard Drive Replacement: шаг 3, изображение 2 из 2
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
  4. Samsung NP305E5A-A03US Hard Drive Replacement, Hard Drive: шаг 4, изображение 1 из 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Hard Drive Replacement: шаг 5, изображение 1 из 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  6. Samsung NP305E5A-A03US Hard Drive Replacement: шаг 6, изображение 1 из 2 Samsung NP305E5A-A03US Hard Drive Replacement: шаг 6, изображение 2 из 2
    • Pull the panel towards you to remove the panel.
  7. Samsung NP305E5A-A03US Hard Drive Replacement: шаг 7, изображение 1 из 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Hard Drive Replacement: шаг 8, изображение 1 из 2 Samsung NP305E5A-A03US Hard Drive Replacement: шаг 8, изображение 2 из 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  9. Samsung NP305E5A-A03US Hard Drive Replacement: шаг 9, изображение 1 из 1
    • Remove the Hard Drive by lifting it towards you.
Заключение
2 участников успешно повторили данное руководство.
Oyinda Olatundee
Участник с: 11/01/16
125 Репутация
1 руководство автора
Команда
Baylor, Team 5-7, Williams Fall 2016 Участник Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 членов
Автор 5 руководств
Один комментарий
Necesito un hard drive model: NO305E5A-A05US
Secundino Herrera - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 8
За последние 30 дней: 27
За всё время: 1,795
