Введение
This guide will help you replace your hard drive. You may want to use this guide if your computer runs slow
Выберете то, что вам нужно
Turn your laptop upside down so that the battery component is facing you.
Place your thumbs on the lock tabs.
Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
Pull the battery out of the laptop towards yourself to safely remove the battery.
Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
2 участников успешно повторили данное руководство.
