Введение
This is a step-by-step guide of how to remove your RAM in order to replace it.
Выберете то, что вам нужно
Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Place your thumbs on the metal tabs.
Push outwards on the metal tabs to release the RAM.
2 участников успешно повторили данное руководство.
