Введение
If your hard drive is bad, or you need a larger hard drive, this guide will show you how to replace your hard drive.
Запчасти
No parts specified.
  1. Lay the laptop down so that the bottom is facing up.
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Slide the two plastic tabs to the opposing sides.
    • Slide the two plastic tabs to the opposing sides.
  3. While both are in the unlocked position, slide the battery out.
    • While both are in the unlocked position, slide the battery out.
  4. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  5. Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  6. Slide the cover 1/4" towards the front of the laptop.
    • Slide the cover 1/4" towards the front of the laptop.
  7. Then, lift the cover off.
    • Then, lift the cover off.
  8. Slide the  hard drive  1/4" towards the front of the laptop.
    • Slide the hard drive 1/4" towards the front of the laptop.
  9. Then, lift the drive up and out.
    • Then, lift the drive up and out.
Заключение
James Kingrey
Участник с: 04.10.2018
766 Репутация
Автор 6 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 1
За всё время: 76
