Введение
If the optical drive isn’t working correctly, this guide will help you replace the drive.
Выберете то, что вам нужно
Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
Find the screw between the hard drive and the model label. Then remove the M2.5X5 screw with a Phillips #0 screwdriver.
Почти готово!
Заключение
