Введение
If you find that your laptop is having connection issues and isn't resolved after the given steps on the troubleshooting page, then replace the Wifi card.
  1. Lay the laptop down so that the bottom is facing up.
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Slide the two plastic tabs to the opposing sides.
    • Slide the two plastic tabs to the opposing sides.
  3. While both are in the unlocked position, slide the battery out.
    • While both are in the unlocked position, slide the battery out.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  5. Look for the compartment with the Wifi symbol on it.
    • Look for the compartment with the Wifi symbol on it.
  6. Using a  Phillips #1 screwdriver, remove the 5 mm screw located beside the Wifi symbol.
    • Using a Phillips #1 screwdriver, remove the 5 mm screw located beside the Wifi symbol.
  7. Gently pry up cover using a plastic spudger or opening tool.
    • Gently pry up cover using a plastic spudger or opening tool.
  8. Gently remove the two wires attached to the Wifi card by using a plastic opening tool or plastic spudger to pry up from under where the wire is attached.
    • Gently remove the two wires attached to the Wifi card by using a plastic opening tool or plastic spudger to pry up from under where the wire is attached.
  9. Using the Phillips #0 screwdriver, remove the M2.5x3 mm screw holding in the Wifi card.
    • Using the Phillips #0 screwdriver, remove the M2.5x3 mm screw holding in the Wifi card.
  10. Gently pull out the Wifi card.
    • Gently pull out the Wifi card.
Заключение
James Kingrey
Участник с: 04.10.2018
766 Репутация
Автор 6 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 80
