Введение
This guide helps users to replace the ODD/HDD/Memory Cover successfully by following these easy steps.
Выберете то, что вам нужно
Flip the laptop over so that the bottom is facing toward you.
Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
2 участников успешно повторили данное руководство.
