Введение
This guide helps users to replace the Wifi card successfully by following these easy steps.
Выберете то, что вам нужно
Look for the compartment with the Wifi symbol on it.
Using the Phillips #1 screwdriver remove the M2.5X5 screw, located beside the Wifi Symbol.
Using the plastic spudger, carefully pry the Wifi panel off.
Gently remove the two wires attached to the the Wifi card by using the plastic spudger to pry from underneath the attachment points.
Using the #2 Phillips screwdriver, remove the M2.5X3 mm screw holding in the Wifi card
2 участников успешно повторили данное руководство.
