Введение
The CD drive is a major component in this laptop. Users will be shown how to replace the CD drive in this guide.
Выберете то, что вам нужно
Turn the computer off.
Disconnect the charging cable from the laptop.
Flip the laptop face down on a flat surface.
While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
Locate the ODD/HDD/Memory panel.
Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
Slide the ODD/HDD/Memory panel away from the device to remove it.
Locate the screw on the right side of the SDD port.
Remove the 2.25 mm screw located on the right side of the SDD port with the Philips #0 screwdriver.
Еще один человек закончил это руководство.
Один комментарий
Hie guys my laptop is not displaying
please help what should i do
