Введение
This guide will demonstrate the process of replacing one of the keys on the keyboard.
Выберете то, что вам нужно
Turn the computer off.
Disconnect the charging cable from the laptop.
Flip the laptop face down on a flat surface.
While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
Place the inner retainer piece into the outer retainer piece by inserting the posts into the grooves on the outer retainer piece.
Once the retainer is attached, press the key onto the retainer, it will make a snapping sound when in place.
