Введение
In this guide you will be learning how to remove the battery from your Samsung NP5230U4BL laptop. This will enable you to replace a damaged damaged or outdated battery to potentially improve battery life. Before attempting to remove the battery, be sure to ground yourself with an anti-static wrist strap and have a Philips #00 Screwdriver, as well as a Nylon pry tool on standby. Also carefully follow the given instructions including the cautionary warnings.
Выберете то, что вам нужно
Using the Phillips #00 screwdriver, remove all ten 1.5 mm screws from the back cover of the laptop.
Using your dominant hand, pinch the tab on the back panel to the right and remove it.
Using the Phillips #00 screwdriver, remove the two 1.5 mm screws that are under the panel.
Using the plastic opening tool, start in the upper-left hand corner of the laptop and pry horizontally to the upper right-hand corner.
Again starting in the upper left-hand corner, pry down vertically towards the bottom left-hand corner of the laptop.
Using your dominant hand, grasp the left side of the back cover and gently pull it up. This should disengage the prongs on the bottom and right edge of the base.
On each side of the portion that is jutting out, there is one, silver 1.5 mm screw. Using the Phillips #00 screwdriver, remove these two screws.
Using the plastic opening tool, carefully separate the battery from the plug that connects the battery to the circuit board.
Using your dominant hand, carefully lift the battery vertically out of place, making sure to handle with care and to not bump any other parts of the computer.
4 участников успешно повторили данное руководство.
