Введение
This guide covers how to replace the battery for the Samsung Series 5 NP540U3C-A02UB.
The battery provides constant power to the device. This gives the laptop its portability and makes it possible to use the device without being plugged into a wall outlet for long periods of time. The battery may need to be replaced if the device appears to be overheating or has a short battery life. If the device exhibits these symptoms, see our troubleshooting guide for possible causes before attempting to replace the battery.
The Samsung Series 5 NP540U3C-A02UB uses a 7.4 V rechargeable Lithium Polymer battery. Ensure that such a battery is chosen before attempting a replacement. A compatible battery is provided below.
Выберете то, что вам нужно
Gently release the 3 clips holding the HDD cover with the plastic opening tool.
Remove the HDD cover from the device.
Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
Remove the following screws holding the case together:
6x 4mm Phillips #00 screws.
3x 6mm Phillips #00 screws.
Using the opening tool, remove the two rubber pads just above the hard drive cover.
Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
Еще один человек закончил это руководство.
