Введение
This guide covers how to replace the speakers for the Samsung Series 5 NP540U3C-A02UB.
The speakers are responsible for playing audio for the device. The speakers may need to be replaced if no sound is coming from the laptop, or sound has bad quality. If the sound on your laptop is not working adequately, see our troubleshooting guide for possible causes and solutions before attempting to replace the speakers.
Выберете то, что вам нужно
Gently release the 3 clips holding the HDD cover with the plastic opening tool.
Remove the HDD cover from the device.
Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
Remove the following screws holding the case together:
6x 4mm Phillips #00 screws.
3x 6mm Phillips #00 screws.
Using the opening tool, remove the two rubber pads just above the hard drive cover.
Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
Using the plastic opening tool, gently release the connector for the speaker(s) you are replacing.
Using the metal spudger, scrape away the adhesive underneath the speaker that binds it to the laptop casing.
Remove the speaker from the case.
