Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This is a guide for replacing the RAM of the Samsung NP550P5C-T01US for those individuals wanting to add more RAM or replacing a defective RAM. Firstly, you must remove the screws and place them in a safe location, so they won't get lost. Then remove the cover. After that remove your RAM pushing the clips on the sides inward and pull it out, remember to not touch the golden contacts to avoid any oil from your hands to block/disturb any current running from your device to the RAM. After all these steps are completed, you will just need to re-do all these steps in reverse order.
Запчасти
  1. Unscrew  the screws that are holding  the cover in place. Slide open the cover of your RAM.
    • Unscrew the screws that are holding the cover in place.
    • Slide open the cover of your RAM.
    • Remember to place screws in a safe location.
  2. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Remove your RAM pushing the clips on the sides inward and pull it out remember to not touch the golden contacts remember to not touch the golden contacts
    • Remove your RAM pushing the clips on the sides inward and pull it out
    • remember to not touch the golden contacts
  4. Slide in the correct RAM type Push the RAM by the sides downward until you hear a click
    • Slide in the correct RAM type
    • Push the RAM by the sides downward until you hear a click
    • re-do all of these steps in reverse order from step 2-1
Заключение
carlos
Участник с: 10.09.2018
169 Репутация
Автор 2 руководств
Команда
Gateway, Team S1-G1, Luster Fall 2018 Участник Gateway, Team S1-G1, Luster Fall 2018
GCC-LUSTER-F18S1G1
5 членов
Автор 2 руководств
Один комментарий
Do you know how i can replace the entire keyboard?
thanks.
rayrahimikamal - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 201
