Введение
Use this guide if your computer is overheating, or if you are hearing a sound originating from the fan.
Выберете то, что вам нужно
First turn the computer over so you are looking at the back panel.
Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
Once the cable has been removed from its housing you are free to remove the fan from the laptop.
You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
Еще один человек закончил это руководство.
