Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to replace a damaged front case or open the case to access other components of your camera.
  1. Orient the camera so the button panel and LCD are facing you. Use a spudger or fingernail to open the battery compartment on the right side of the camera. Use a spudger or fingernail to open the battery compartment on the right side of the camera.
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Push the blue trapdoor to the left to release the battery, and remove the battery. There is no battery shown in this photo.
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Remove the 4 mm Phillips #00 screw hiding in the external flash port.
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Remove the four 5 mm Phillips #00 screws from the lens assembly.
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Remove the metal lens mount by hand or with tweezers.
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Use tweezers to remove the inner metal ring.
    • Use tweezers to remove the inner metal ring.
  8. Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Use your hands to slowly pull the front casing away from the camera. The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
Заключение
Kelsea Weber
Участник с: 12.11.2015
17 428 Репутация
Автор 32 руководств
Команда
iFixit Участник iFixit
Community
135 членов
Автор 14 475 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 410
