Введение
The back cover holds the screen in place and protects the internal components of the camera.
Выберете то, что вам нужно
Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
Remove the dial by lifting upward with your fingers.
Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
Use your fingers to lift the plastic viewfinder cover upward.
Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
Еще один человек закончил это руководство.
